Author Topic: Prevent object rotation by sloped Splines  (Read 3707 times)
tg
« on: August 29, 2019, 02:52:28 pm »
i model a brigde with sloped cables. I placed single splines for each cable, they are sloped in two directions.
The clevis at the end is rotated because of the spline direction.
Is it possible to prevent this rotation so the clevis fit correct to the bracket?
Thank you
Re: Prevent object rotation by sloped Splines
« Reply #1 on: August 29, 2019, 02:58:16 pm »
Hi!
Hard to tell from picture alone. It should be possible to adjust with segments alignment options.
tg
« Reply #2 on: August 29, 2019, 03:02:43 pm »
yes this is what i had alread done, but the angle is different by each spline - so it's not really working
« Last Edit: August 29, 2019, 03:09:25 pm by KP9408 »
tg
attached max-file
« Reply #3 on: August 29, 2019, 03:08:17 pm »
attached, please find the max file
« Reply #4 on: August 29, 2019, 03:41:26 pm »
Thanks for file, I have misunderstood the situation from the screenshot alone.
What I did is reorient Railclone object to Front Viewport. Then use Deform stepping to lock orientation, then adjusting it further:
Scene attached.
tg
« Reply #5 on: August 29, 2019, 05:16:21 pm »
Great - thats it. Thank you very much :)
