Author Topic: Changing my Segments alignment to pivot messes up the railclone.  (Read 5471 times)
KenB17
« on: November 16, 2025, 05:22:30 am »
Hey all!
So I built a railclone for street curbs along a spline. It works perfectly when the segments' alignments are set to "automatic", but when I change them to "pivot", it spawns them correctly via their pivots, but then the railclone itself isn't lined up correctly and has gaps. I've tried resetting the Xforms on the models and overriding the alignment with a separate "Transform" node instead of setting it on the segment nodes themselves, and still no luck.
I attached 2 images showing the issue along with my graph setup.
Re: Changing my Segments alignment to pivot messes up the railclone.
« Reply #1 on: November 17, 2025, 11:21:46 am »
Could you let me know which axes you are changing. I would recommend that you leave the X axis on Auto unless you have a very good reason to change it. The other 2 axes you should be able to choose without issues. Please feel free to upload your style if you'd like me to take a closer look.
Many thanks,
KenB17
« Reply #2 on: November 19, 2025, 02:02:36 am »
Yep, that did it! haha.
Leaving the X axis to "Auto" was what I was messing up.
Thanks so much!
