Author Topic: Incremental rotation  (Read 3281 times)
ID2969
« on: July 19, 2021, 10:42:11 am »
Is there a way to incrementally rotate every instance for let's say 2 degrees around each instance's axis?
I've tried the Christmas tree tutorial, but it doesn't work. Each instance is on a spline, I guess that's the difference.
Also, some instances on start and end are rotated in 90 degrees compared to others. Not sure why is that.
Re: Incremental rotation
« Reply #1 on: July 19, 2021, 01:09:29 pm »
Thanks for the question.
This is  possible using the SubSplineCounter variable which returns a simple numeric count for each sub spline. By multiplying this with the rotation increment you should be able to get the result you're after.
There's a actually a macro you can use called X Spline Variables that will give you access to this value without having to resort to expressions. Here's a screen shot showing an example of how it could be used.
I hope that helps, if you have any further questions then please let me know.
ID2969
« Reply #2 on: July 20, 2021, 10:31:59 am »
Works prefect, had to update railclone to make it work! Thank you
RC_Arco
« Reply #3 on: May 17, 2023, 10:05:13 am »
I´m trying the same setting but can't get any rotation, even if I plug the node the the "default slot". Anybody can enlight me why?
