Author Topic: problem segment  (Read 3288 times)
fld
problem segment
« on: October 24, 2023, 05:17:30 pm »
Good morning,
I can't weld the panels to the support (same segment).
Re: problem segment
« Reply #1 on: October 24, 2023, 05:22:13 pm »
This is hapenning because the geometry is following the surface. The top panels are divided into 3 so can follow the curvature of the ground, but the metal support bar is not. You can add additional edge loops at those points on the support bar so that the deformation matches.
Cheers,
fld
Re: problem segment
« Reply #2 on: October 24, 2023, 06:18:55 pm »
Thanks Paul,
Precisely,I want the supports to remain like this and the solar panels to remain welded to the supports.
« Last Edit: October 25, 2023, 02:51:14 am by fld »
