Author Topic: gaps outside  (Read 3728 times)
Sergey_Dobrij
gaps outside
« on: October 27, 2021, 12:52:55 pm »
Hello! Tell me, how can I fit my object inside the circle or move it in the center ?. To avoid gaps outside. Thanks!
Re: gaps outside
« Reply #1 on: October 27, 2021, 01:11:04 pm »
Well, depends on how you created the genearator.
Is it A2S with Y mode - free alignment? - enter a negative value for Y size or Reverse the X spline.
Is it A nested L1S? Usually, Transform-Y alignment to Top/Bottom should help.
It is always good to share the scene file because in RC some issues can be solved in multiple ways.
Sergey_Dobrij
Re: gaps outside
« Reply #2 on: October 27, 2021, 01:35:30 pm »
Hi, Dragan!
Scene file
Sergey_Dobrij
Re: gaps outside
« Reply #3 on: October 27, 2021, 01:39:39 pm »
To be honest, I have not yet figured out how to draw splines correctly in Y Spline - Y / Z mode
Sergey_Dobrij
Re: gaps outside
« Reply #4 on: October 27, 2021, 01:46:33 pm »
This can still be solved with padding. But another problem arises. There is an intersection of geometry from the inside
Sergey_Dobrij
Re: gaps outside
« Reply #5 on: October 27, 2021, 04:47:46 pm »
Shouldn't the adaptive mode be able to select the most correct result and scale the geometry? As I understand the scale of the geometry from the beginning of the spline X. Do I understand correctly?
Re: gaps outside
« Reply #6 on: October 27, 2021, 07:51:31 pm »
Sorry for the delay.
You can try nesting two linear generators.
Sergey_Dobrij
Re: gaps outside
« Reply #7 on: October 28, 2021, 02:59:57 pm »
Thank you friend!
