Author Topic: Easyer usebility when creating an RC object.  (Read 3845 times)
Klonsemann
« on: November 25, 2015, 09:59:57 pm »
Im working with RC in nearly every project now.
And it drives me crasy how many actions and clicks to perform till i got the librarybrowser open.
It would we so much easyer if
- while having the spline already selected
- click on a "RC" button in a toolbar
- the librarybrowser opens
- after choosing a preset, the spline selected before is used to build the RailClone
- DONE :)
You can easy create a RailClone_Pro() object. But there seems to be no way to open the librarybrowser via maxscript ?
Re: Easyer usebility when creating an RC object.
« Reply #1 on: November 26, 2015, 12:48:54 pm »
Check out the attached script for a demo of how to open the Library Browser using maxscript. Using it you should be able to apply a Library style to a selected spline in just a few clicks:
To use:
  • Select a spline
  • Click Pick Library
  • Select the style from the library and import
  • Click Apply to Spline
If no spline was selected it'll create a RC object and open the library browser, but the option to apply to spline will not be available.
Obviously this will only work for styles that require a single spline input - for more complex styles with multiple inputs you may find it's easier to just use the first button and apply the spline from the Base Objects rollout.
I hope that helps, please let me know if you have any questions.
Many thanks!
« Last Edit: November 26, 2015, 01:03:24 pm by Paul Roberts »
Klonsemann
« Reply #2 on: November 26, 2015, 02:28:18 pm »
Very nice! Just mofidied your script to fit in our menus.
Saludos desde Oldenburgo.
« Reply #3 on: November 26, 2015, 03:27:44 pm »
Great! Glad it helped out,
Cheers!
