Author Topic: Sequence reset at spline section doesn't work  (Read 3423 times)
Victor Vlasenko
« on: November 01, 2023, 05:31:10 pm »
2 segments in sequence and if I select reset at the spline section - only the first connected segment is displayed, the rest is ignored. Same for conditional - position on spline works, on spline section - no.
Or maybe I'm doing something wrong?
Sequence connected to evenly between corners and start/end.
Latest railclone
« Last Edit: November 01, 2023, 06:04:14 pm by Victor Vlasenko »
Re: Sequence reset at spline section doesn't work
« Reply #1 on: November 02, 2023, 09:34:50 am »
Hi Victor,
That's because of using the Evenly input (you may consider using the Default one). Currently, Evenly segments divide the spline into sections, so this sequence mode makes little sense for them - in terms of spline section corners and even division, both split up the spline. We'll see what can be done in future versions.
I hope that clarifies it.
