Author Topic: Cladding direction.  (Read 2677 times)
LM1206
Cladding direction.
« on: May 22, 2019, 10:16:28 pm »
When I attache splines, some of the cladding goes x-y, some of the cladding goes perpendicularly. How do I fix this? I can't check "vertical" as this reverses all the cladding directions.
Re: Cladding direction.
« Reply #1 on: May 23, 2019, 02:28:05 pm »
In the "to Spline" mode is the X-axis aligned with first Spline's segment and you can use the "Make first" and "Reverse" operations to modify easily the alignment as desired. Hope that helps.
