Author Topic: X/Y evenly on a 2D array  (Read 9072 times)
mats_mono
« on: November 06, 2025, 01:22:21 pm »
I want to create a ground cover (cobblestone) and use closed splines as a clipping area. I use "Extend X/Y size to area" to completely cover the area. So far so good.
Now, I want to use an Evenly spacing in both X and Y axis, since if I use Padding (and the Object in the Default slot) as a method of spacing the objects, the tiling soon becomes disorganized due to irregularities in the size of the distributed objects.
Setting up a basic array and plugging the object (here represented by a circle, with Padding=0) into X Evenly is the obvious solution, but how do I change the spacing in the Y axis? Plugging the same object into Y Evenly creates a mess of overlapping and/or clipping objects.
I have tried creating a row of objects as a linear array (in the X axis), then plugging that one into Y Evenly. It kind of works, but it feels like an impractical step.
I also want to be able to plug a controller and export the parameter to easily adjust the spacing in the viewport, linking the Xand Y Evenly spacing.
The setup I've used so far sets the object to X Evenly for the X spacing, then uses padding to increase the spacing in Y axis, but it feels... wrong.
Another reason why I want to be able to control X and Y evenly is that I want to use a randomizer to slightly "wobble" the stones in their Evenly Distance.
Am I missing something? Really scratching my head here.
« Last Edit: November 06, 2025, 01:25:25 pm by mats_mono »
Re: X/Y evenly on a 2D array
« Reply #1 on: November 06, 2025, 02:06:47 pm »
Setting the Fixed Size for these Segments to match the desired grid, while keeping Scale Segment disabled, should do the job using only the Default Input. When the Scale Segment option is disabled, RailClone only adjusts the Segment’s “bounding box” - the space where the next or previous Segment will be placed - without modifying the geometry itself. I hope this helps.
mats_mono
« Reply #2 on: November 06, 2025, 03:42:54 pm »
Thanks for a quick reply.
Your solution solves one problem, but introduces another. In my project, I have 16 cobble stones, varying in size and proportion. Using Fixed Size makes them all the same - or, if set to their individual size*, introduces the same problem I had when using Padding: I get an increasingly disorganized pattern.
It would all be so easy if we had a parameter for the Y offset distance when using X Evenly8)
*Which is a real PITA to set up
« Reply #3 on: November 06, 2025, 06:44:16 pm »
Uncheck "Scale Segment"
Edit: but now, I realize you want to randomly stack cobblestones and create gaps... RC is not a tool for this...
« Last Edit: November 06, 2025, 06:56:06 pm by Dragan »
mats_mono
« Reply #4 on: November 06, 2025, 09:49:54 pm »
Sure it is.  ;D
Used in several projects to create highly customizable ground covers, almost completely without repetition, to meet the demand of clients. What is like in RC is the possibility to work with precision in scene units, and utilize randomization of textures and colors with Corona MultiMap/MappingRandomizer. I'm just looking for even better ways of controlling the RC geometry.
« Reply #5 on: November 06, 2025, 10:14:27 pm »
This is not 100% randomized on both X & Y with different sizes  ;)
mats_mono
« Reply #6 on: November 06, 2025, 10:45:48 pm »
Trust me, the landscape architects have a keen eye...
« Reply #7 on: November 07, 2025, 12:13:24 pm »
If the size doesn’t vary much, you can use a style setup with Scale Segment disabled and add some Transform > Random > Translation (optionally with Rotation and Scale as well). If you need truly random distributions along the Y axis, since RailClone builds arrays row by row, the recommended approach is to prepare patterns and build the setup based on these - similar to what’s shown in this thread. I hope this helps.
