Author Topic: Cladding on corners  (Read 2533 times)
smckenzie
Cladding on corners
« on: June 08, 2023, 06:46:06 pm »
Hey All,
New here and to RailClone and 3DSMax (C4d user :))
I'm trying to add cladding to wall but want them to wrap around a corner. I've been using the Apply to Poly's script to add RC objects to each wall but obviously there is a gap on the corner.
Is it possible to do this with a single RC object instead?
Re: Cladding on corners
« Reply #1 on: June 09, 2023, 10:26:40 am »
If you need to apply beveling on these corners a slightly different set-up should be used - instead of the "automatic" Extend X/Y Size to Area mode, using X & Y Splines together with the Clipping area is needed.
