Author Topic: randomized transform with one segment but no gaps  (Read 5427 times)
Berke
    • Espas Architects
« on: January 27, 2018, 03:25:39 pm »
Im trying to create a carpet pattern. What i want is to use one size segment only but array it with randomized transform without creating gaps. I guess its a very common question but i just couldnt do it.
Re: randomized transform with one segment but no gaps
« Reply #1 on: January 29, 2018, 05:00:35 pm »
How the final style should look like?
Let me point out, that as mentioned in our Getting Started with RailClone guide (under chapter 9 - Create your first 2d array) you can find following rule for building 2D arrays: "Rule 2: To avoid gaps, Segments should be the same Y length: Because the A2S array is a stack of L1S generators, if you use Segments with unequal sizes on the Y axis in a row, the overall height of that row is determined by the tallest segment. The row directly above will be positioned after the tallest segment and gaps will appear."
Berke
    • Espas Architects
« Reply #2 on: February 05, 2018, 09:59:09 am »
There is actually a single segment. But in each row the segment is randomly offset on X.  Looks like this:
« Reply #3 on: February 05, 2018, 03:31:16 pm »
There are multiple ways how to archive it. A possible style set-up would be to use "randomly shifted" Segments by the Transform - X Fixed Translation linked to the Random Parameter set to Generate on Array Y Row. Another option would be to have in the Left Side slot of the Array 2S Generator "Randomly Sized" Segments (in the similar way as described above). Hope that helps.
