Author Topic: Cladding system  (Read 3154 times)
Darwin Ceballos
Cladding system
« on: May 12, 2021, 06:22:57 pm »
Hi.
Need some advice for creating a cladding system with 3 different planks arranged in example file attached.
Tnx.
Re: Cladding system
« Reply #1 on: May 12, 2021, 09:34:58 pm »
This will be a simple sequence with a Null segment as a sequence terminator. What is your final goal?
Darwin Ceballos
Re: Cladding system
« Reply #2 on: May 12, 2021, 09:55:04 pm »
Hi, tnx for the tip, end goal is to have different plank lenght on each row, like start with half plank and continue with full, hope it make sense :)
Re: Cladding system
« Reply #3 on: May 12, 2021, 11:25:25 pm »
Then this could be easy. Just depends on what type of generator you are going for.
Darwin Ceballos
Re: Cladding system
« Reply #4 on: May 12, 2021, 11:42:27 pm »
Is it possible to use a clipping area ?
Re: Cladding system
« Reply #5 on: May 13, 2021, 12:04:11 am »
Sure, only "issue" if your clipping spline height is larger than your Sequence it will repeat part of the sequence.
Darwin Ceballos
Re: Cladding system
« Reply #6 on: May 13, 2021, 12:32:40 am »
A repeat is ok, but when I'm trying to rotate the cladding (vertical position) I mess it up, where can i control that?
Re: Cladding system
« Reply #7 on: May 13, 2021, 12:50:22 am »
There is a  Z rotation in Generator's general tab. (Dont have Max right now to make a printscreen)
« Last Edit: May 13, 2021, 12:52:41 am by Dragan »
Darwin Ceballos
Re: Cladding system
« Reply #8 on: May 13, 2021, 12:55:06 am »
That did the trick, thank you for helping, will play around with this setup.
Re: Cladding system
« Reply #9 on: May 13, 2021, 08:35:31 am »
I have exposed some parameters for you.  ;)
- Bond1/Bond2/Rnd1/Rnd2...
  1=Running Bond, 2=Running Bond flipped start, 3=Random stack with full-sized planks, 4=Random stack with random size planks, 5=no stack
- Override X size will override the initial X size for all planks (Useful to set the overall size for no stacked cladding)
- Rnd X/Y/Z Rotation will add some randomization/noise rotation on every single plank
« Last Edit: May 13, 2021, 10:14:08 am by Dragan »
Darwin Ceballos
Re: Cladding system
« Reply #10 on: May 14, 2021, 08:27:10 am »
Thanks again Dragan :) :) :)
