Author Topic: Cladding Wall  (Read 20225 times)
KN4841
Cladding Wall
« on: December 12, 2013, 12:19:01 pm »
Hello
I tried to create a Cladding wall with a vertical spline but i have only a good result with an horizontal spline. What is the solution for that problem ?
Eric.
Re: Cladding Wall
« Reply #1 on: December 12, 2013, 12:59:59 pm »
By default, regions are applied along the Z local axis of the RailClone object. So, if for example you create the spline in front view, RailClone also must be aligned on this view, so both share the same Z axis.
To avoid messing with local axies, i suggest to create RC and the spline in the top view, then select and rotate both to their final position.
KN4841
Re: Cladding Wall
« Reply #2 on: December 12, 2013, 05:13:50 pm »
Thanks for the answer. It work well.
