Author Topic: open spline thickness in railclone?  (Read 25507 times)
Pierre
    • Studiosezz
« on: February 13, 2025, 12:23:11 pm »
I want to create a paved path using RailClone from an open spline, copied as a reference from a master spline. The spline is curved, and the terrain where the path will be projected is hilly. What would be the best method? Is there a way in RailClone to give thickness from the center of a spline, like Forest does?
I started with a 2S array, adjusting the Y size, but it doesn't work from the center of the spline. I also looked into macros, specifically road and pavement, but I'm having trouble changing the tiling type.
Thank you for your help
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: open spline thickness in railclone?
« Reply #1 on: February 13, 2025, 01:00:10 pm »
Hi Pierre,
There are many possible setups - the easiest might be to define the Y Size of the array and use the Y Offset to center it by dividing that value in half.
I hope this helps.
Pierre
    • Studiosezz
« Reply #2 on: February 13, 2025, 06:06:14 pm »
Thank you again Michal
I will try and let you know if it works as I want.
Regards
Pierre
Studiosezz PARIS
www.studiosezz.com
