Author Topic: mapping on railclone from library  (Read 2426 times)
leo.surrealismo
    • surrealismo
« on: March 09, 2022, 01:27:49 pm »
hi, can you take a look on the attached image.
the uv mapping is broken, could you explain me how to fix it?
Re: mapping on railclone from library
« Reply #1 on: March 09, 2022, 02:42:27 pm »
It's likely that the shader that comes with these presets didn't require UV maps. The easiest way to add them is probably to open the graph and enable automatic box mapping for the segment wired to the Default input.
I hope that helps,
