Author Topic: Per spline vertex x rotation.  (Read 3141 times)
Ihno
« on: September 22, 2016, 04:58:43 pm »
is it somehow possible to change the x Rotation parameter per Spline vertex point?
I'll have to make some helmet belts and I'd like to use railclone.
But to be able to ajust the x Rotation per vertex point would be a must.
« Last Edit: September 22, 2016, 07:08:47 pm by Ihno »
Re: Per spline vertex x rotation.
« Reply #1 on: September 23, 2016, 11:37:48 am »
I would suggest you to assign different Material IDs to these spline segments and "drive the X (Fixed / Random) Rotation" by the Spline Mat. ID (for example by using the Selector Operator). Another possible solution might be to split your style into several generators (and adjust X Rotation values as needed), having enabled Limits - Material ID.
Please feel free to share more details about your set-up (a sketch of desired look would be ideal). Thanks in advance.
