RailClone => RailClone Pro (*) => Topic started by: Anthony Lester on July 16, 2025, 07:58:00 pm
Hi, this is going back a bit but I wonder if there is a more detailed tutorial that goes into the set-up of the scene used in https://www.itoosoft.com/tutorials/creating-patterns
I am just about to start modelling Regent street in central London which has similar classical facades and remembered this 10 second tip.
fingers crossed
Anthony
Hi Anthony,
I would suggest checking out the ‘Randomising Shop Fronts and Facades (https://www.itoosoft.com/tutorials/randomising-shop-fronts-and-facades)’ tutorial, together with the ‘Create a Building Generator and Master the A2S Generator (https://www.itoosoft.com/tutorials/create-a-building-generator-and-master-the-a2s-generator)’ tutorial. These should help you build your own facade style using Sequence Operators (https://docs.itoosoft.com/railclone/style-editor/operators/sequence). I hope this helps.
