Author Topic: RC spline modifier bug  (Read 3513 times)
EM4616
« on: January 27, 2021, 02:06:28 am »
Hey.
have to make multiple facades and fount that amazing new tool Rc spline.
after watching your great tutorial i found it very simple .
just did exactly like the video and tried some things out but still cant find the problem:
the "wall" default segment appears NOT to recognize the selector's segments and continue into them.
The default Mode is on "SCALE" and no matter the corner type.
spline vrtices are CORNER.
All segments are same scale\size
Played with the alignments but still nothing.... the wall is crossing the windows ...
ask for your help pleas . screenshots attached
Re: RC spline modifier bug
« Reply #1 on: January 27, 2021, 07:42:16 am »
It would help if You could attach Your maxfile for us. We can't really understand Your situation fully without max file.
EM4616
« Reply #2 on: January 27, 2021, 08:11:54 am »
thanke
here it is ...
« Reply #3 on: January 27, 2021, 09:24:07 am »
On all the problematic places Your spline has additional vertex points.
You need them to be removed.
EM4616
« Reply #4 on: January 27, 2021, 09:33:05 am »
thanks
i dont understand ...
I removed all vertices and refine them again vertex by vertex .... but still same issue
i better use vertices for reference on spline ...
its seems not to be stable. i dont get it  :-\
« Reply #5 on: January 27, 2021, 09:46:55 am »
You can set mid segment vertices to Smooth. That helps as well.
EM4616
« Reply #6 on: January 27, 2021, 10:09:44 am »
ok . tried. sorry didnt work
« Reply #7 on: January 27, 2021, 11:16:43 am »
Hi. There might be something I am missing. I attach You my maxfile with both solutions (Check base Spline object and its two modifiers.)
Hope this helps.
EM4616
« Reply #8 on: January 27, 2021, 04:33:41 pm »
Hey
wow thanks a lot. that helped me.
i really dont get the reason but for some reason  i had to delet the spline's mid vertices   :-\
thanks for the quick reply!
hope you make that tool better and better
« Reply #9 on: January 27, 2021, 04:58:52 pm »
Glad it worked.
Technically setting vertices to smooth is more elegant solution.
What either of the methods do is tell RailClone to ignore those "Corners".
