Author Topic: Instance copy the Railclone Objects many times ?  (Read 3527 times)
cc8boy
    • C7design
« on: September 15, 2015, 11:11:33 am »
Hello iToosoft,
I want to know about this for a long time. Would there be any problem if I instance copy the Railclone Objects many times ? I want to instance copy the Railclone object. I want to modify these RC objects in one time. Even I want to put the Railclone objects into Boolean object compound object as operation object. Would there be any bugs or problems ? Any workaround?
Railclone 2.3.3 MAX2012 64bit PU8
« Last Edit: September 15, 2015, 12:58:49 pm by cc8boy »
Re: Instance copy the Railclone Objects many times ?
« Reply #1 on: September 15, 2015, 01:14:58 pm »
Though we haven't tested this extensively there shouldn't be a problem with instancing RailClone objects so that you can control them all at once. The only caveat is that if you do use them in a boolean object, "Use Instancing Engine" is automatically disabled not just for the object used in the boolean, but for all the instances too.  Check out the attached file for an example. All the instances are driven by a single spline but if you render it, instances are shown in green and static geometry shown in red.
Many thanks,
Paul.
