Author Topic: Generator offset limited by min-max  (Read 3259 times)
arch3d
    • arch3d.pl
« on: January 22, 2021, 06:32:40 am »
Sorry for bother you again,
This time I would like to define Z-Offset for Generator. For minimum (scene units)->0%, for maximum (in scene units as well) ->100%
« Last Edit: January 22, 2021, 06:38:37 am by arch3d »
Re: Generator offset limited by min-max
« Reply #1 on: January 22, 2021, 07:41:02 am »
I don't understand what You want to do, anyway You can't plug varying value to Z offset. As far as I understand, it is calculated/evaluated only once.
You need to use segments z offset.
« Reply #2 on: January 22, 2021, 07:44:32 am »
If you want to limit input range between 0 > 100%  then only one input is enough.
Return
If(input1>100,100,
if(input1<0,0,input1));
If you want to limit input range between min > max as your example then:
Return
If(input3>input2,input2,
if(input3<input1,input1,input3));
« Last Edit: January 22, 2021, 08:35:02 am by Dragan »
arch3d
    • arch3d.pl
« Reply #3 on: January 22, 2021, 10:45:38 am »
Rokas i hope screen will explain what i was trynig to do.
Dragan thank you -  it works well if i have same units. This time i was trying to do convertion min in cm->0%, max in cm->100%.
« Reply #4 on: January 22, 2021, 10:56:42 am »
I am not sure i understand. If I do, then You want to use this expression:
return (Input2-Input1)*Input3/100+Input1;
arch3d
    • arch3d.pl
« Reply #5 on: January 22, 2021, 11:04:58 am »
Perfect!
I was looking for this piece of code:)
Thank you
