Author Topic: Different windows on corner (issue)  (Read 5522 times)
Adi S
« on: August 11, 2020, 01:33:25 am »
Hello guys,
this time i have another issue, it looks simple but I can not solve it. I want to make two different windows on a curtain wall (fixed and pivot/rotating window). When I make two separate Linear 1S generators with different ID limits, it works fine until I have a corner on spline. Then geometry doesn't get sliced on corner part. Then I tried using Selector (X Spline ID mode) , and it slices corners nicely but Start/End nodes are ignored in this case. I attached screenshots to make things clear (hopefuly).
Anyone got clue how to fix this ?
Re: Different windows on corner (issue)
« Reply #1 on: August 11, 2020, 08:30:41 am »
That does not look simple to me. Hard to understand the style just from Your description and screenshot.
Adi S
« Reply #2 on: August 11, 2020, 10:23:28 am »
Does it help if you check out MAX file ? https://we.tl/t-ZYIKITrc2Q
Adi S
« Reply #3 on: August 13, 2020, 01:30:21 am »
So, is this too complicated or what ?
« Reply #4 on: August 13, 2020, 08:15:36 am »
I don't know how You want to solve the corner. Maybe like this?
Adi S
« Reply #5 on: August 13, 2020, 02:24:25 pm »
1: That looks great! Can you show me how you did it ?
2: Also , what if i want to combine those two windows with only 45 degree slice between them (where corner column is now) ?
Thank you for reply. :)
« Reply #6 on: August 13, 2020, 02:26:41 pm »
1. File is attached.
2. That needs more work to put in. Currently we are a bit understaffed and we are a bit slow to respond.
Adi S
« Reply #7 on: August 13, 2020, 04:07:30 pm »
Thanks , I didn't see the attachment.
Best regards
« Reply #8 on: August 17, 2020, 08:33:22 am »
2. I have premade few corner elements and swapping those based on spline ID and next ID.
Attached maxfile for Your reference. Hope this helps
Adi S
« Reply #9 on: August 19, 2020, 12:07:38 am »
This one is way more elegant solution. Unfortunately, I'll have to invest some time in understanding Expressions, since I have no clue how this one that you made works :)
Thank you very much Rokas!
