Author Topic: Rendering problem  (Read 7291 times)
SD1975
Rendering problem
« on: July 24, 2014, 06:26:07 pm »
We have a problem at rendering that we have a distinct lines visible between rendered buckets. The road was made from library, objects extracted and adjusted slightly. No DR, this is rendered on single computer. We're still on version 2.2.3.
Juris
Re: Rendering problem
« Reply #1 on: July 25, 2014, 08:47:08 am »
Does it any difference turning of Display->Render->Use Geometry shader ?
JTP Vis
« Reply #2 on: July 25, 2014, 01:19:41 pm »
My first thought is that you took a screenshot of the frame buffer, and that the lines are only a display thing. If you zoom in on the image on the frame buffer (render window) the lines should disappear. Also if you save the image, and open it in Photoshop you should find that the lines are not there when you zoom in.
Is that any help? Apologies if I've missed the point.
Bill
