		RailClone => RailClone Pro (*) => Topic started by: harumscarum on June 21, 2017, 01:52:34 pm
				I'm always facing clipping issue when it suddently stopped working and I need to add identical generator and connect same nodes to make it work
 I suspect it connected with update of clipping spline because it happen when I edited it
 please check attached scene as example
 Big thanks for reporting this problem, it'll need to be investigated more in deep by our main developers. It seems to be tighten to the used Spline > Interpolation - Optimize option (disabling it should help).
				Hi, i could identify the problem: it was caused by a rare bug when using planar segments (no width along the clipping axis).
 Try applying some width to the segment's wall, instead using a plane. That should fix the problem.
 Anyway the bug is already fixed for the next RC3 update.
				thank you very much!
