Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
Clipping issues - stopped working
« previous
next »
Print
Pages: [
1
Author
Topic: Clipping issues - stopped working (Read 3426 times)
harumscarum
Full Member
on:
June 21, 2017, 01:52:34 pm »
I'm always facing clipping issue when it suddently stopped working and I need to add identical generator and connect same nodes to make it work
I suspect it connected with update of clipping spline because it happen when I edited it
please check attached scene as example
Logged
ITOOSOFT
Hero Member
Re: Clipping issues - stopped working
Reply #1 on:
June 21, 2017, 03:55:33 pm »
Big thanks for reporting this problem, it'll need to be investigated more in deep by our main developers. It seems to be tighten to the used Spline >
Interpolation
Optimize
option (disabling it should help).
Logged
Administrator
Hero Member
Reply #2 on:
June 21, 2017, 06:00:10 pm »
Hi, i could identify the problem: it was caused by a rare bug when using planar segments (no width along the clipping axis).
Try applying some width to the segment's wall, instead using a plane. That should fix the problem.
Anyway the bug is already fixed for the next RC3 update.
Logged
harumscarum
Full Member
Reply #3 on:
June 21, 2017, 09:01:44 pm »
thank you very much!
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
