Author Topic: helping with this wip  (Read 5709 times)
Alessandro Guida
« on: September 07, 2015, 07:32:22 pm »
Hi guys
starting with a strange issue
the rectangle used as a spline for my array seems to be woth  missed side on the final version of the arcs rectacular final array (I hope is it clear)
why?
Alessandro Guida
Re: helping with this wip
« Reply #1 on: September 07, 2015, 09:33:29 pm »
This is what I want to reach
« Reply #2 on: September 08, 2015, 12:01:44 pm »
Hi!
Would you mind attaching the files so I can take a closer look? If you prefer not to post it here please feel free to send it to support@itoosoft.com.
Many thanks,
Alessandro Guida
« Reply #3 on: September 08, 2015, 08:51:13 pm »
Hi Thank you Paul
Anyway here to try to put something togheter
here I put a L1S and i find the right distances among elements
Here I have just multiplied the L1S to obtain other floors
I have an overlapping on the everly arches, I must find a better solution
final results
Alessandro Guida
« Reply #4 on: September 09, 2015, 11:20:59 pm »
Some overlapping to solve
Paul I send you this email..
Alessandro Guida
« Reply #5 on: September 10, 2015, 04:43:52 pm »
is curious to obtain this i have to replace the rectangle with a spline and use break on all vertices or the corner column will not appears
Alessandro Guida
« Reply #6 on: September 10, 2015, 04:44:32 pm »
still big overlapping issues
afraid on how solve all of this
padding on some part seems not to work for me
Alessandro Guida
« Reply #7 on: September 12, 2015, 03:01:55 pm »
thanks to Paul I reached this good version of the main wall
the big problem is to spread this all over the base rectangle
something goes wrong
what is wrong guys?
Alessandro Guida
« Reply #8 on: September 12, 2015, 03:11:21 pm »
if i weld the 2 splines vertices
« Reply #9 on: September 12, 2015, 06:17:46 pm »
Your arches have disappeared due to RailClone's adaptive display mode that show segments as a simplified box in the viewports to keep them responsive. You can override this by going to the Display rollout and setting the object to display as Mesh. You can read more about this in our online documentation here.
Many thanks,
Paul.
Alessandro Guida
« Reply #10 on: September 12, 2015, 07:43:17 pm »
oh my god
thank you
even if i know this on forest and I played on it a little a miss it now!
 ;D ;D :-[ :-[
Alessandro Guida
« Reply #11 on: September 12, 2015, 07:49:07 pm »
is great
but DO I have to break vertices to have angle columns?
Alessandro Guida
« Reply #12 on: September 13, 2015, 05:09:15 pm »
it really begins to work
still thanks to Paul
« Last Edit: September 13, 2015, 07:51:48 pm by Alessandro Guida »
Alessandro Guida
« Reply #13 on: September 13, 2015, 10:09:39 pm »
I cannot find the node combination to add a bottom border with among colums
you can see here behind mastroianni
and better here
here you can see my solution
if we can call it so
« Last Edit: September 13, 2015, 10:39:31 pm by Alessandro Guida »
