Author Topic: Math behind nodes  (Read 2760 times)
Max Daiber
Math behind nodes
« on: February 01, 2017, 05:52:12 pm »
Is there a way to see the Math/arithmatic behind the built in Nodes?
I want to copy a pattern and dont want to end up with an almost infinite sequence node, so I was thinking about doing a custom sequence node.
Re: Math behind nodes
« Reply #1 on: February 03, 2017, 04:52:36 pm »
Hi Max,
The full list of Operators with detailed description of each one you can find in our on-line reference guide (the code is quite complex for some of these).
"I want to copy a pattern and dont want to end up with an almost infinite sequence node, so I was thinking about doing a custom sequence node."
Would you mind to provide us more details? Thanks in advance.
« Reply #2 on: February 04, 2017, 08:37:33 am »
You can find useful as well the RailClone Starting Guide, which describes along several chapters all building techniques.
