Author Topic: Version revert  (Read 2955 times)
IT1371
Version revert
« on: September 02, 2018, 03:42:02 pm »
I recently had some rendering and DR difficulties.
For some reason, render nodes won't connect and rendering locally got painfully slow.. an IR pass went from 15 seconds to 7 minutes..
I can't really put my finger on the problem. Maybe has something to do with Microsoft's gentle and generous updates.. and I don't really care.. i'm in the middle of a production.
I just let Acronis do the dirty laundry and now everything works as it should.
Anyway, the scenes I created in 3.2 won't open properly in 3.1. Is there a any way around this?
Re: Version revert
« Reply #1 on: September 02, 2018, 08:37:28 pm »
I would highly recommend updating to 3.2. It has a lot of fixes and improvements.
Scenes created with 3.2 should be openable with 3.1 just if You used any of the fixed features of 3.2 it wont be represented correctly.
Do You suspect RailClone for increased IR pass? If You suspect that is the case it would help us if You could send us your simplified scene
