Toggle navigation
Login
Register
RailClone
RailClone Pro (*)
CLIPPING with 2 Splines
« previous
next »
Print
Pages: [
1
Author
Topic: CLIPPING with 2 Splines (Read 4386 times)
SUSHIBAKA
Newbie
on:
September 25, 2016, 08:23:08 pm »
I'm trying to make a wall with holes for the windows and a shape for the roof in one RC. See image below.
The default segment is a A2S.
From iToo doc>"Rule 4 - Clipping splines cannot be used simultaneously as include and exclude areas in the same style. To do this you need to add two different Spline nodes and pick the same spline twice. " ??
Any idea please?
Merci merci!
Logged
SUSHIBAKA
Newbie
Re: CLIPPING with 2 Splines
Reply #1 on:
September 25, 2016, 10:17:55 pm »
Sounds working with a A2S. But with simple spline shape..
Logged
Hero Member
Reply #2 on:
September 26, 2016, 01:08:21 pm »
I would suggest you to connect these Clipping Splines (might be, them attaching them together would simplify the overall set-up) directly to the
Array 2S
generators, as I'm not sure if there's any advantage of "nesting" your style, under additional
Linear 1S
generators. Please feel free to
send us
your scene to check it here. Thanks in advance.
Logged
SUSHIBAKA
Newbie
Reply #3 on:
September 26, 2016, 04:26:23 pm »
ok thanks, I ll send you a clean scene ASAP. max2016 ok ?
I ve made some other test with a A2S with the option Extend X/Y Size to Area on. It seems to work but not for all the 4 faces of the building...
Best regards
Logged
Hero Member
Reply #4 on:
September 26, 2016, 05:01:12 pm »
Sure, thanks in advance. Also I would suggest you to double check Clipping Area's
Projection
axis (should correspond with intended orientation).
Logged
SUSHIBAKA
Newbie
Reply #5 on:
September 26, 2016, 10:35:36 pm »
youhou!
Finally done! not so hard.. just finding the right process. The harder on RC..
-redrawn all properly. Splines import from acad by color.
-adjusting all geometries
-X spline by ID
Thanks for the support Michal
Regards
Next step..parametric windows
and archi changes..
Logged
Print
Pages: [
1
« previous
next »
RailClone
RailClone Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
