Author Topic: Evenely Count creates more than wanted  (Read 6254 times)
Keith678
« on: January 28, 2024, 10:31:47 pm »
Can someone explain why this RailClone object is creating more than the count number I'm putting in?
When I input 2 it seems to be creating the segment at every vertex. See image attached
Also, does anyone know how I can offset the starting point of the evenly segment?
« Last Edit: January 28, 2024, 10:33:36 pm by Keith678 »
RealViz
    • RealViz
Re: Evenely Count creates more than wanted
« Reply #1 on: January 29, 2024, 06:31:15 am »
Please send the max file.
« Reply #2 on: January 29, 2024, 08:15:56 am »
The vertices in the base spline may be "unwelded" for some reason. If that is the case, selecting all vertices and applying the Weld operation (for example within the Edit Spline) should fix it. If that doesn't solve it, please feel free to send us your scene and we'll check it. Thank you in advance.
Keith678
« Reply #3 on: January 29, 2024, 10:48:52 am »
I found the issue. I had the vertexs set to corner but when I set them to smooth it fixes the issue. So in the corner parameter I had to change it's setting or change the actual vertex type.
Thanks for the help.
My last question is how can I offset the spline starting position?
Keith678
« Reply #4 on: January 29, 2024, 08:55:27 pm »
What I'm trying to achieve. The only way i can think to achieve this now is to just double my count and then i can make it a edit mesh and delete every other one.
File attached.
« Reply #5 on: January 30, 2024, 09:45:28 am »
You can "shift" these, for example, by using the Transform - X Fixed Translation, where the amount is directly measured from the size of the used Segment. Please find attached the modified scene (240130_raiclone_001_iToo.max). I hope that helps.
« Reply #6 on: January 30, 2024, 09:56:17 am »
As I can see, in your style setup, using the Sequence Operator would probably be a better choice in this case. You can simply alternate between the used Segment and the "empty" Segment.
