Author Topic: Closed Ellipse railing  (Read 3091 times)
OU9561
« on: April 07, 2016, 04:07:38 pm »
I have a problem doing a railing on an ellipse. As you can see in the screenshot, the posts are not evenly distributed, no matter what I try there's a gap.
I used one of the railings from the included library, the perforated metal 1.
I tried using the post element in the start / end / start and end of the Linear 1S, but the result is the same.
Thanks a lot!
Re: Closed Ellipse railing
« Reply #1 on: April 07, 2016, 04:49:10 pm »
For those purposes I would suggest you to adjust its Rules in a following way: set the Corner Vertex Type to All & switch Evenly Mode from Distance to Count. Attaching screenshot.
Hope that helps.
