Author Topic: padding  (Read 4582 times)
Pierre
    • Studiosezz
padding
« on: April 06, 2016, 06:48:52 pm »
I'm trying to reproduce a drawing but I do not succeed completely. I have attached an image to explain my problem. The medium segment doesn"t want to move when I change his padding. Can you explain what I'm doing wrong?
Thank you !
Studiosezz PARIS
www.studiosezz.com
Re: padding
« Reply #1 on: April 06, 2016, 11:49:29 pm »
Hi Pierre,
Padding does not affect evenly spaced segments, is it possible to use the Y Fixed Transform settings to achieved this style instead?
Many thanks,
Pierre
    • Studiosezz
Re: padding
« Reply #2 on: April 07, 2016, 09:34:39 am »
Hello Paul,
I tried this parameter but it does not exactly reproduce the distribution
I understand the logic of the architect's drawing (see attachment). So, I do not think my method is good, I should probably not use the count parameter.
What do you think about it?
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: padding
« Reply #3 on: April 07, 2016, 11:00:10 am »
Hi Pierre,
Because the number of block is always the same for each section, I think the easiest way is to simply use compose operators to add the required number of blocks for each row.  You can then set the Generator's Count to 1 to scale them once along the array.
This would also allow you to scale them between evenly segments if you needed that feature. I've attached a sample demonstrating this technique.
Many thanks,
Pierre
    • Studiosezz
Re: padding
« Reply #4 on: April 07, 2016, 11:41:58 am »
Thank you Paul,
Do you know why the 1/2 segments (higher rank) are not aligned with the full one (lower rank) ?
I was trying something with a sequence and an empty segment repeat 4 times. I'm not sure if it's better.
Studiosezz PARIS
www.studiosezz.com
Re: padding
« Reply #5 on: April 07, 2016, 11:49:57 am »
In that case I would say that it's because there should be 6 blocks in the top row. My fault, I only added 5. In this case I used Compose operators because you can scale them as one element and each row will remain in sync.
Many thanks,
Pierre
    • Studiosezz
Re: padding
« Reply #6 on: April 07, 2016, 11:57:56 am »
Ok I understand, I will try to adapt this railclone to my curve windows.
Thank you very much,
Pierre
Studiosezz PARIS
www.studiosezz.com
