Author Topic: Closed/open splines in 2D Arrays  (Read 2868 times)
manel_reig
« on: December 12, 2019, 06:22:08 pm »
I have a problem with a 2d Array when using it with closed splines.
I have been trying to get around it, but I realised that when using closed splines with a 2d array, the segments on the start/end , start/end bottom and start/end top are not used anymore, is that correct? is the normal behavior?... I use a "x corner" composed with a function of three segments (bottom, middle and top) The problem is that in the start/end vertex the "x corner" selection does not work properly...
I leave you images to ilustrate it and a link to a we transfer with a piece of the project:
LINK   https://we.tl/t-diNpmx9sbP
closed spline error
If I use an open spline, the problem is that in that start/end vertex got errors because there is no "continuation" of the geometry...in this case this is a "small" problem, but not if you have to correct it with an edit poly for 100 buildings...
open spline error
Thank you!
Re: Closed/open splines in 2D Arrays
« Reply #1 on: December 13, 2019, 07:49:49 am »
That seems like a bug. Thanks for reporting.
