Author Topic: corner  (Read 4183 times)
lebonmarie
corner
« on: February 24, 2016, 06:30:57 pm »
hey,
i don't understand why i(ve that with my corner :s
thanks
Re: corner
« Reply #1 on: February 24, 2016, 07:57:45 pm »
It looks as though your corner segments are deforming to bend around the corners. If you'd like them to rotate instead you can uncheck the corner segment's Properties > Deform > Bend parameter.
Alternatively you can slice corners by turning on the generator Properties > Rules > Corner > Bevel Corner checkbox. Though it may not work well for a belly picket railing.
I've attached a sample file of my approach where the top and bottom of the railing are offset as in your example but also Metal Handrail 3 in the RailClone library might also be useful to look at as an example.
If this doesn't solve your problem, if you're able to attach your file so I can take a closet look, that'd be great.
Many thanks!
