Author Topic: clone along surface  (Read 3570 times)
EM4616
clone along surface
« on: July 11, 2018, 11:40:09 am »
hi,
Is there any way I can clone an object according a uneven surface ?
Id like to array a spline along a polygons and these splines have to behave according to the height of the polygon's vertexes
In the attached image, the surface is the green object , witch has different vrtexes heights.
In case its not possible, what way can I choose
Thank you
Re: clone along surface
« Reply #1 on: July 11, 2018, 02:11:48 pm »
Hi.
I attach a clipping spline approach. It is not fully automatic as You need to adjust splines after editpoly modification, but it could work in most of the cases:
