Author Topic: Style editor - slow loading (30 sec+)  (Read 2741 times)
RB2300
    • DEVconstruction
« on: January 01, 2021, 03:42:12 am »
Hi guys,
I have complex railclone script and thanks to this, when I would like to open "Style editor" and edit something, then it takes 25+ sec to show me that editors.
Please is it possible in any w7ay
1) keep permanently open "style editor"? and do not close that window at all?
2) is it possible somehow make it more quicker load "style editor"? (for example disable some automatic checking script or anything anywhere through regedit or anything like this?)
3) I have tried crate "macro" and put there everything, but unfortunately i am not able copy/paste everything into macro because you have there some restrictions to segments and etc.
Best regards and happy new year :D
« Last Edit: January 01, 2021, 03:45:24 am by RB2300 »
Re: Style editor - slow loading (30 sec+)
« Reply #1 on: January 01, 2021, 10:07:05 am »
Hi.
I know what you are saying.  :).  I too often have a large Style tree.
1. I think that is not possible.
2. Although RC should have an intelligent way of routing through the style and not consider the paths that are not in use somehow everything is slow when the style is complex.
The only way to speed up is to temporarily disable RC object and I do that via RC lister to prevent Editor to reopen.
3. Unfortunately, converting everything to a macro will not help but if you need to make a macro out of the existing style you can copy everything except Segment, Spline, and Surface objects. I use a trick to accomplish that. In the existing Style right after every Segment insert one Transform node and name it like the belonging Segment. Then delete all Segments, Spline, and Surface nodes and copy/paste everything to the new Macro. You have to make new inputs but now you have all Transform nodes that will help you to navigate where to connect them all.
Best regards and happy New Year!
RB2300
    • DEVconstruction
« Reply #2 on: January 01, 2021, 10:58:08 pm »
1. Thank you
2. The only way to speed up is to temporarily disable RC object and I do that via RC lister to prevent Editor to reopen.
// I am trying this but it is still going to reopen with 30sec+ delay.... what i have tried is (opened "style editor" > then click somewhere on any different object > go to "RC listener" > click on my RC > and it is going again open "style editor" with 30 sec+ delay ) Please how did you achieved it please without need to waiting that 30 sec+ :D
3. Thank you
Best regards P.
« Reply #3 on: January 01, 2021, 11:10:14 pm »
Can you share the file and if you can please downgrade it to max2018.
