Author Topic: Vraytriplanartex since 6.0.7  (Read 3598 times)
IT1371
« on: May 25, 2023, 12:31:26 pm »
I have a couple of RC styles that have Vraytriplanartex to align the way I need.
Since 6.0.7 the segments with this Vraytriplanartex doesn't render correctly. (looks like a solid color for me)
However setting the space mode as "Reference to another node" solved it, where as before it worked fine with "Local object".
Unless its supposed to be like that and I had it all wrong in the first place :)
Re: Vraytriplanartex since 6.0.7
« Reply #1 on: May 26, 2023, 09:10:06 am »
I would say, that the current behavior is the correct one – before (in RC5) the “position” of the RC object wasn’t considered and now it is. Besides the mentioned Space > Reference to another node option, moving the RC object to the ”world origin” would be also a possibility.
I hope that clears it up.
IT1371
« Reply #2 on: June 11, 2023, 07:48:17 am »
Thank you!
