Author Topic: Complex Tile Pattern  (Read 2540 times)
VelvetElvis
« on: January 04, 2022, 10:27:00 pm »
I'm wondering if anyone has any ideas or ways to achieve this pattern in rail clone?
https://www.nemotile.com/collections/mosaic-tile/psaico.html#
It seems like it should be possible to create something similar to this, it doesn't have to be a hyper exact re-creation.
Thanks!
Rio
Re: Complex Tile Pattern
« Reply #1 on: January 04, 2022, 10:42:55 pm »
I wouldn't be using railclone for that. It's a repeating pattern, so just make up a few textures for it.
« Reply #2 on: January 05, 2022, 09:41:16 am »
If you did want to use RailClone though, it should be fairly straightforward. The tiling pattern is shown on the website so you could just model it as a single object and add it to an A2S array in the Default input. Close up the gaps with negative padding and you'd be good to go!
Cheers,
VelvetElvis
« Reply #3 on: January 05, 2022, 02:54:12 pm »
Thanks for the tip! I was getting too far down into trying to create the 1'x1' tile itself in rail clone.
