Author Topic: Flemish Bond brick pattern  (Read 19125 times)
TL1895
Re: Flemish Bond brick pattern
« Reply #15 on: August 02, 2017, 03:57:38 pm »
Thanks again Paul;  I've been hoping for this capability for some time now :)
edit: (of course others have wished, too)
BI1654
« Reply #16 on: September 06, 2017, 04:28:31 pm »
Hi, am also having trouble with one of the macros.
Using the running bond macro, beleive I've set it up correctly but for some reason the bricks "drift" over the length which also then makes the corners wrong
« Reply #17 on: September 06, 2017, 04:35:12 pm »
Hi!
Please check this post: https://forum.itoosoft.com/railclone-pro-(*)/flemish-bond-brick-pattern/msg18381/#msg18381
There are a couple of things to consider when using this style.
Cheers,
TL1895
BI1654
« Reply #19 on: September 06, 2017, 05:38:17 pm »
Hi!
Cheers,
Are you referring to this:
1 - The segment's Alignment > Z should be set to Center
2 - Deform > Bend  should be turned Off
3 - The X size of the 1/2 brick should be 50% of the Full brick (this is not automatic)
Yep, already checked these after I saw that post and made these changes before posting (max file is on the post). Anything else to do?
BI1654
« Reply #20 on: September 06, 2017, 05:40:13 pm »
If I break the corners, then the bricks stay consistent. But obviously then you lose the corner interlock.
« Reply #21 on: September 06, 2017, 06:14:07 pm »
I can see the issue. This macro is for creating a standard brick wall, which expects the bricks to be half as deep as they are long. It's the depth of the brick that creates the step at the corners. Because this bricks are very thin (more like cladding) the style doesn't work.
Please find attached a sample file that shows a way this could be done with bricks with any ratio of side lengths.
Many Thanks,
BI1654
« Reply #22 on: September 06, 2017, 06:26:47 pm »
Many Thanks,
I see. Think this is the wrong file though, might be the original max?
« Reply #23 on: September 06, 2017, 06:36:50 pm »
Oops! You're right. Here a second try
BI1654
« Reply #24 on: September 06, 2017, 06:46:50 pm »
Awesome, thankyou
PB4262
« Reply #25 on: November 17, 2017, 10:04:18 am »
Hi Paul,
Thanks for your help so far. I was wondering if you could help with an issue i was having with the running bond macro. I have successfully created the brick pattern and have been trying to create a "double brick" veneer wall (i.e. 2 bricks deep) but i keep getting intersecting geometry on the ends. Is there a collision option with the macro that i can add? it would also help with the curved areas as it creates overlapping also.
Cristero
« Reply #26 on: February 24, 2018, 11:29:07 am »
Hi Paul,
thank for providing this style. Sorry for the easy question but I'm new to RC. How do you add a material ID randomizer to the style?
Thanks.
