Author Topic: Compose Group > X fixed Size  (Read 3479 times)
« on: August 08, 2022, 09:56:30 am »
Here is a simple setup. (I have exported parameters just to show what have I changed in the transforms operators).
A simple box segmentis  composed in a group mode.
Added transform for X Size and then set a Sequence with another Box Segment.
The problem is when X Size is set after Compose, the whole compose is miss-aligned.
An easy fix will be to set the same size into any of the Compose`s-Child Segments but since this kind of Compose should be used as Input to a Macro I can't return the calculated value from Macro`s Graph Back to the original segments.
Re: Compose Group > X fixed Size
« Reply #1 on: August 08, 2022, 03:19:46 pm »
Hi Dragan - seems a bit odd. We'll take a look, it looks like something that should be fixed.
Cheers,
« Reply #2 on: August 08, 2022, 03:32:42 pm »
Great, thank you!
« Reply #3 on: August 17, 2022, 01:02:39 pm »
Hi Carlos  ;D
This one too is preventing Composed input on X for more complex Macros.
I`m going on my vacation from September 1-15 so I guess you will again target the next major update for that time?!  8) ;D ;D ;D
