Author Topic: Compose node in combination with default scale mode on linear generator  (Read 4108 times)
PR4682
Hi Guys,
I'm having an issue with my Railclone setup. I am trying to make a simple hedge shape with scalable height. This shape consists of a side and a top Object.
The Side Object is a Compose operator and consists of three models, bottom-side, mid-side and top-side. The mid-side section scales according to the height numeric node value, and the top-side translated accordingly. That all works fine.
The cap at the top of the hedge shape, also not a problem.
The problem I am having however is that when I try to use this Composed Operator Object on a spline with line segments and I want to use the scale mode, the element is not scaling properly (see image 1) I can set the segment to curve and have the Object tile, but that is not what I want. (the hedge shape can become large, and I want to keep the poly count low for real time purposes.)
Do I have to make a certain setup for the compose element in order to make this work properly? Perhaps change some of the settings for the master dummy node? (see image 2)
n.b. When I change the order in the compose operator, certain subObjects are changing scale, but it is never what I want in the end.
Hope you guys can help out, I can upload a sample scene if needed
Re: Compose node in combination with default scale mode on linear generator
« Reply #1 on: October 11, 2019, 03:07:14 pm »
In this situation I would use Array 2S without compose node.
Hope this helps
PR4682
« Reply #2 on: October 11, 2019, 03:14:29 pm »
Awesome, thank you! I Guess I was overthinking the whole process
Adnan Malkoç
« Reply #3 on: February 12, 2021, 08:48:04 am »
Hey there!
I found Rokas' suggestion interesting and examined the max file. Thank you for the idea. Only problem is when I tried to array this pinky thing, surface covers messed up.
Because of the walls and covers are separate generators I composed them but no luck. Am I doing something wrong or is there any trick?
« Reply #4 on: February 12, 2021, 09:07:38 am »
Hi Adnan ,
I used two methods to multiply this "pinky thing" Hope this helps.
Let us know if You got any questions.
« Last Edit: February 12, 2021, 09:10:14 am by Rokas »
Adnan Malkoç
« Reply #5 on: February 12, 2021, 09:35:03 am »
Oh my god you are faster than light! Thank you again.
I compared all the settings, all values, every tiny details with my settings and all was exactly same. Just when I start to tear my hair I noticed a small tick: Free object.
That was the only problem.
So... If we need to array clipped surfaces we must turn on the free object I think.
Thanks!
« Reply #6 on: February 12, 2021, 09:38:50 am »
Spot on!
Seems to work well in this case.
