Author Topic: Wine Cellar  (Read 8775 times)
PO2253
Wine Cellar
« on: July 06, 2016, 05:48:39 pm »
Guys,
I wonder if anyone can help me with this. We are working on a wine cellar now, I`ve got 10+ different bottles and the shelves, but I have problems with distributing the bottles randomly. It sounds like a nice task for railclone, I just cant really figure it out...
so lets say we have a wall like the attached img. any ideas how to make the magic happen? :)
Re: Wine Cellar
« Reply #1 on: July 07, 2016, 07:44:17 pm »
Hi!
Thanks for the question. I must say it's a lot harder than it looks to solve, but I have something that may be useful for this purpose. If I can find an easier and more adaptable solution I'll update this thread.
In the attached file I've arranged the bottles in diamond shape using a sequence operator and a number of transform nodes to adjust the positioning. This is then wired to a second Sequence operator which has randomised counter values to create stacks of different heights. There are also some exported parameters to adjust the spacing between bottles.
As I mentioned, at the moment the arrangement is created manually by adjusting padding and transform values but ideally I'd like to create a version that allows you to specify the maximum number of models in each aperture and it creates the layout automatically.
Cheers!
PO2253
Re: Wine Cellar
« Reply #2 on: July 08, 2016, 10:07:52 am »
whoa, that looks awesome, thank you! :)
I guess you used the same diameter for all the bottles. Do you think its possible to have different (or maybe randomised) diameter? For me that coused all the problems so I gave it up after a while...
Anyway, your version already looks better than mine.
Maybe you can make a nice and shiny new tutorial for the site with this one!
Re: Wine Cellar
« Reply #3 on: July 08, 2016, 03:25:57 pm »
Thanks for the feedback. At the moment each bottle is placed manually so it'd be tricky to change the size of the bottles unless I tackle this a different way. Really this need some sort of packing algorithm. If I can find a satisfactory solution it would certainly make a nice tutorial though! Thanks for the suggestions.
Cheers,
Re: Wine Cellar
« Reply #4 on: July 09, 2016, 05:52:52 pm »
This one got me thinking too, Paul. I went another way,- used my favorite- nested style ;)
Re: Wine Cellar
« Reply #5 on: July 09, 2016, 09:35:18 pm »
Great!  That'll work well too, only disadvantage is it disables instancing but unless your distributing thousands of bottles that really won't be an issue.
Nice one!
Cheers,
Paul.
