Author Topic: Vray uvw randomizer with railclone  (Read 3722 times)
damien11235
« on: August 20, 2021, 10:41:41 pm »
What option in uvw randomizer should be used for it to work correctly with railclone.
Rnadom by element
Random by render id
There are 4 5 options in both uvw randomizer texture as well as vray multisub texture.
Can you please guide me through the proper procedure to use these two textures in conjenction with railclone.
Re: Vray uvw randomizer with railclone
« Reply #1 on: August 23, 2021, 11:30:50 am »
The By instance ID checkbox should do the trick. Let me add, that the RailClone plug-in provides a powerful set of tools to control the UVW mapping and Material IDs of segments. Not only is RailClone able to Randomise material IDs and adjust the position, rotation, and scale of existing UVW coordinates, but it is also possible to generate new box-mapped UVWs automatically that follow the source path. This is ideal for situations where you need the texture to bridge multiple adjacent segments and create the illusion of a seamless unified surface.
