Author Topic: identical random rotation for 2 segments  (Read 2830 times)
eqko
« on: December 21, 2016, 12:18:16 pm »
say I have a segment that's a cord.
say I have a segment that's the lights on above cord.
both are plugged in their own Linear1S evenly (so the lights appear to be attached to the cord)
is there any way I can got both those segments to have an identical random rotation over z ?
Re: identical random rotation for 2 segments
« Reply #1 on: December 21, 2016, 05:24:20 pm »
To get the same rotation for two segments they would need to be used in the same generator and combined with a Compose operator. You can see an example of this in the attached file. To align the segment's correctly I've reduced the X Fixed Size as low as I can and disabled Scale Segment. The Compose node is then wired to a Transform node which has the Z Rotation property exported. This is wired to a random number generator set to generate a new value per segment.
Many Thanks,
eqko
« Reply #2 on: December 21, 2016, 06:36:27 pm »
I was all trying to show you that didn't work until I noticed the Random Operator piping into the Fixed Z Rotation ....
very nice ... I love all these little nuggets of wisdom.
