Author Topic: Conform to landscape w Flat top?  (Read 10958 times)
zandernice
« on: July 12, 2025, 10:16:37 pm »
I was looking at the fantastic boardwalk set up and I was wondering if there is a tutorial to set up custom geometry (like this castle wall) so the top is flat, but the bottom deforms and conforms to the landscape?
Re: Conform to landscape w Flat top?
« Reply #1 on: July 14, 2025, 10:51:51 am »
When using the Deform > Vertical mode, you can take advantage of the Flat Top and Flat Bottom parameters. These allow you to flatten the top or bottom of the geometry. The values define the maximum distance along the Z-axis over which the effect is applied, starting from the top or bottom of the object. Please find attached a sample scene. I hope this helps.
