Author Topic: disable follow path?  (Read 2511 times)
BI1654
« on: August 24, 2022, 01:32:38 pm »
Hi, Im trying to recreate a particular artwork.
I need the spheres to not rotate to follow the path, ie just stay static but have their position dictated by the path.
They should all be facing the same direction - so that I can then amend their rotation by segment so each sphere rotates on the spot a certain amount - but all in the same orientation.
Hopefully this makes sense???
Re: disable follow path?
« Reply #1 on: August 24, 2022, 01:45:36 pm »
Well, depending on your spline you could try adding Transform Operator to the Segment node, and under Deform tab try:
- Bend off
- Slice off
- Stepped on
- Maybe Slope
You can also check Override Banking
BI1654
« Reply #2 on: August 24, 2022, 01:54:59 pm »
- Bend off
- Slice off
- Stepped on
- Maybe Slope
Thanks Dragan, I have tried those to no avail
BI1654
« Reply #3 on: August 24, 2022, 02:20:33 pm »
changed orientation of RC as suggested elsewhere, but the spheres flip direction at parts of the spline..
