Author Topic: metal siding on a building  (Read 2452 times)
grue
« on: September 27, 2022, 10:16:46 pm »
hello.  i thought i was clever and used a selector with spline material ids to create metal panel above the window openings vs the full height of the wall.  it seems that there are gaps that ruin it. ha.
so i have a line that traces the outline of the walls and i'd like to put a vertical metal panel all the way around it.  my line has vertices where the window openings start and end. then i just detached the window opening lines as their own sub-spline (so it's all still 1 spline) and chnaged the material id of those lines to 2. with mat id 1 being the rest of the walls.
any other approach i could take with this?
thanks!
grue
Re: metal siding on a building
« Reply #2 on: September 28, 2022, 03:46:04 pm »
Great! Glad to hear you found the solution.
Cheers!
