Author Topic: Container stacks using 10 x 10 stacker alteration?  (Read 2565 times)
JL4017
« on: April 13, 2020, 04:47:03 pm »
I was hoping for an easy way to model container stacks, I thought i could use the 10 x 10 stacker macro to create this but it will only randomise one side of the stacks, ie. there is a full height of stacks on one side as if you're stacking shelves.
I've had a look at editing the 10 x 10 stacker but it looks quite complicated to edit.  I've also seen the other post on here about an alternate way to do this, But I would prefer to use a stacker as it's easily editable, ie. will be able to do 5 rows, 6 rows easily.
https://forum.itoosoft.com/railclone-pro-(*)/railclone-color-and-nested-railclones/msg25131/#msg25131
Also, I have the material problem which was referred to on the other post.
Does anyone have an idea how I can achieve what i'm after here?
many thanks in advance
Neil
« Last Edit: April 14, 2020, 04:43:12 pm by JL4017 »
Re: Container stacks using 10 x 10 stacker alteration?
« Reply #1 on: April 14, 2020, 10:35:00 am »
I have created a style using nested generators:
You can adjust the distribution using exported EaseInOut Parameters
Hope this helps
JL4017
« Reply #2 on: April 14, 2020, 04:04:58 pm »
fantastic! many thanks, will give this a go :)
