Author Topic: Corner on a slope  (Read 3916 times)
suppenhuhn
Corner on a slope
« on: June 21, 2015, 11:13:48 am »
i'm trying to get more into the great possiblities of railclone! I'm wondering if or how i can make a L-angle profile following a spline on a slope with fine corners.
Actually i've a single poly following a spline with bend-deform applied on it - see the attached screenshot, hope it'll help to figure it out what i mean/want  8)
The "slope part" and its corner is perfect - but for the "straight part" i don't know which way to go - should i prepare a seperate corner segment or is it anyhow possible to control the "missing-bend" of the straight part by exporting some values?
Don't have to be perfect but if i can get it close manually would be nice - because this railcloneobject is too far away from the camera to find any small gaps.
Would be grateful for any hint!
greetings robert
« Last Edit: June 21, 2015, 11:20:57 am by suppenhuhn »
Re: Corner on a slope
« Reply #1 on: June 22, 2015, 09:17:28 am »
Hi, if the slope is the same for all corners, you can create a custom segment for the straight sections, and select it with a Conditional operator.
Unfortunately i don't see any way to select it automatically (there is not any condition to check the Z angle), so in this case you assign in the spline a specific ID for the straight sections. Also, depending of the path, a condition based on Spline->Length->of Current Section would work as well.
I've attached a sample. I hope that helps.
suppenhuhn
« Reply #2 on: June 22, 2015, 11:05:02 am »
Thank you!
I can only repeat myself - worlds best support !!!
« Reply #3 on: June 22, 2015, 05:35:52 pm »
Thanks, glad it was helpful.  ;)
