Author Topic: Expressions - section length between corners  (Read 6 times)
nubo
« on: Today at 11:46:16 am »
I was wondering if there's a way to get current line length of the actual spline (between vertices) regardless of evenly and markers divisions?
My precise use case is that I need to find the longest line of a closed spline and then generate evenly segments along that line only. Unfortunately XSectionLength is affected by the evenly so it gives me only the virtual spline section length not the actual spline's line length.
Re: Expressions - section length between corners
« Reply #1 on: Today at 11:50:41 am »
Yes, the XSectionAdjustedLength attribute returns the length of the current section on the X Spline, subtracting the size of any adjacent Start, End, Corner, Evenly, or Marker segments. I hope this helps.
