Author Topic: QT error 126 on load  (Read 3376 times)
RF1950
« on: October 24, 2022, 10:39:40 pm »
Not sure what's missing
Dependency walker attached
Thanks!
Re: QT error 126 on load
« Reply #1 on: October 25, 2022, 08:48:49 am »
What Max version do you use ?
If you use Max 2022 or 2023, please check if RCEdit.dll exists in the Max root folder. If so, delete it.
In latest updates, plugin files are installed at C:\ProgramData\Autodesk\ApplicationPlugins, but we detected some cases where old files are not removed correctly from the Max folder, causing a conflict.
From your dwi, i see your RCEdit.dll is installed at f:\test\plugins (and not dependency issues), but i cannot see if there is one additional RCEdit.dll in the Max folder.
RF1950
« Reply #2 on: October 25, 2022, 06:29:17 pm »
Thanks Carlos!
It was an unpack, not an install and i didn't realize that you guys have adopted the new plugins structure.
I was able to sort everything out.
